SVcummins
Is almost finished ran the welder Out of gas .
Dads getting more farming done than I am! Going to check a field today hopefully it?s dry enough to go
A lot of manure is being hauled in central Mn. I saw 2 4wd JD?s doing tillage in the Sauk River sand today. Other than that just manure. The Belgian said he was giving it a go down in Nicollet earlier this week.
I put a four footer under my truck, just made two brackets to go under the tool box, box (TSC) is strong enough to stand on. Mine is mounted to the chassis is yours mounting to the underside of the body? The box is open in the picture, just took the load cover out of it.
That?s a good looking rig . What are the specs of it ,? This will mount under the bed and I?ll bolt it through the top of the bed
When in doubt add some more iron! There?s not a spec of engineers blood in my veins I like to build about 3 times heavier than it needs to be . I?ll be glad when it gets put on the truck cab can go back to hauling people
87 KW T600 If I remember correct the GVW is 54000. The body dumps and I use it to haul anything and everything.
The race is on here on who can get to the field first we harrowed pasture the middle of March but the fields are wet still around home
