Towing a tractor
Jay87T
Hi guys, my neighbor has a ford tractor, medium size. has Power steering. He is stuck in his back field, wont start. Can he steer his tractor with it not running? I would like to tow him with my Kubota.
Yes he can steer it, but make sure the transmission is set to tow properly.
Just because it is in neutral at one place does not make it safe to tow without damaging things.
I agree with Loren in that it would help for you to get correct replies if tractor model is revealed.
Non running tractors with hydrostatic steering require several steering wheel revolutions to change frt tire angles just a little.
You will have no problem towing a manual transmission tractor in neutral. If it has hydrostatic steering, that could be a problem, but you should be able to deal with that.---------------------Loren
Need to check the manual and see if it says anything about placing the gear shifts in a tow position or lf neutral is ok
(quoted from post at 17:36:23 10/05/20) Hi Dave, what am I looking for, I figured I would just put it in neutral and pull it.
A lot of equipment with manual transmissions have been ruined while being towed in neutral .
There are still spinning shafts that require lubrication.
well if it is like the 706/806 internationals then he wont have steering. and a tow across a field wont hurt a thing. its when you tow them for miles and the same thing goes for some vehicle trans.
and i was going to say its the speed of towing with distance that hurts them. going 3 miles per hr. you are pretty safe.
This is one way not to tow a tractor. He had a guy tow his 44 John Deere b back to his house, the guy with that was going to tow him didnt bother to tighten the chain up and he went from 0 to 10 and then the front end broke (he was probably going to go faster than 10). He ended up getting a different pedestal, steering shaft and a gear.
You will get all kinds of opinions on here, but the correct answer depends on the model of tractor and the transmission. You can and will damage equipment by incorrect towing, and it will be expensive.
Why won't it start? It had to be running to get it stuck. If it's as simple as a dead battery, give it a boost and get it running. A running tractor is gonna be a lot easier to get unstuck.
