Toyota transmission problem
old
Friend has me looking at his car. 1990 Camry with an automatic in it. Any how he lives on a real bad road so the pan is dented up pretty good. Car will not sift in to reverse and tries to go forward pretty much any place you put the shifter. I pulled the cable off the side of the tranny and shifted it by hand and still can not find reverse. So will a dented pan cause this or is he looking at a tranny replacement??
Pull the pan and take a look. I have seen a lump of road junk hit the shift linkage lever hard enough to break the cast iron shift spool in the valve body.
