Tractor gas tanks:
A friend of mine called me one day and asked me if I could help work on his tractor.
He has a Allis 175. So I said sure so he brought it and the problem was that the gas tank had so rust inside it and old float had rotted away that that it was plugging his line ,filter
And carb.
We took off the gas tank, pulled out what was left of the old gas float took a air hose with 125lbs PSI and just blew the tar out of it, and this will sound stupid, but we put a hand full of marbles in the gas tank And blew the tar out of it again, thinking the marbles help
Knock off some of the rust in the tank.
We took the marbles out, and on the end of the line That goes in the bottom of the tank we added a ½ ‘’ chunk of copper gas line that would stick up higher in the tank, hopping if their was any rust left it would plug the hole On the out let of the gas line going to the Carb.
This was 10 years ago and the Allis 175 Is still running and the gas line has not plugged up as of yet. CAN WE CALL THIS RED NECK REPAIR OR WHAT.
And carb.
