Tractor Tires
dpendzic
I bought 2 new Carlisle front tires 6.00-12 for my 4wd tractor---i was intending to install tubes but the tires say tubeless, the old tires were tubeless but had tubes---am i better off with or without tubes???
It depends on your rims. Since you say its for a 4wd tractor the rims/ tractor should be new enough to be all tubeless rims. Are the rims damaged, neglected or rusty in anyway to where a bead would not seal? If no, go tubeless, puncture repairs are easier and cheaper. IMHO the only benefit to tubes is it is easier to keep a tire aired up, less likely have the tire pop off the bead from low pressure due to lack of use or from steep incline sliding/skidding. If you seldom get punctures and use it daily, it will not matter which way you go.
Plus you don't have to worry about getting rust/dirt/corrosion on the rim's bead to let the air out.
Bet your tractor had tubes in the " Tubeless" tires for a reason. I'd put tubes inside your new tires too.
That sounds like a smaller tractor. Does it have a loader on it? If so does the loader get used a lot? If so you might want to tube the tires for the reasons posted in the other replies. The extra weight of a loader and full bucket could be an issue if a tire got a little soft and could get pushed off the bead. That being said most of the newer stuff comes through tubeless and people seem to be getting along okay with it.
It's kind of a toss up. The tubes are such poor quality they don't last and the tires are not much better anymore. They will go to leaking through the sidewalls too. Your choice.
i think i will go tubeless if my rims are tubeless??
Looks good to me. Rims will clean up nicely. Use some bead sealant and a good valve stem.
Tubes were put in last time because someone put something through the tires. Tubes will not prevent you from putting something through a tire. If you do put something through the tire now you won't be putting a hole in a tube in addition to a tire. If you need to add a tube later, you can.
thanks--as you can see in the pics the old tire sidewalls were very cracked so thats probably why the tubes were put in
