$#@*! trailer tires
wjytexas
I hadn't used my gooseneck in a couple of months. Went down and hooked it up this morning to haul to a pasture mowing job. when I pulled the UV covers off one of the right side tires was flat. in 2019 I had 3 of the 4 tires separate in 3 consecutive trips so I put on the 4th new tire thinking I was good. they didn't get much use in 2020 and so far in 2021 not a whole lot either. I'm hoping this is just a mesquite thorn or nail. Glad I hooked up this morning instead of this afternoon. grrrrrrrrrr
Radial tires are only good for six years. I've had a blowout before on a parked trailer. I also have had three trucks and two trailers damaged by radial tires delaminating. It's like running re-treads to have radial tires on a vehicle. You can't go by the appearance of a tire or the amount of tread you have to find the date of manufacturer.
If you're using trailer tires, quit. Use LT tires same as on your truck. I get the same size on my trailer as my truck then put my used truck tires on the trailer.
Did you replace the valve stems when you replaced the tires?
I've had two valve stems rot fail on trailer tires that I should have replaced when I put new tires on. Didn't have new stems on hand so I put the tires on and forgot about it. Came out one morning and one tire was flat. Valve stem split. Didn't change the other one, and found it flat too a few weeks later.
update. the tire was bad. replaced for $16. I was wondering if BFG 265 All Terrains would work on a trailer.
If theses are ST tires, you will have nothing but trouble with then!
LT, bias ply if you can find them, are what I use. They seem to handle the sitting without rotting better, and haven't had one fly apart yet!
Or the heaviest load rating you can find, expensive, but might find some factory take offs or used.
Light truck tires generally carry a load rating of B, C, D, E, or F. This loosely correlates to the older classification of four-ply to 12-ply tires and indicates how much pressure a tire can withstand.
The Load Range F Tire, # AM10501, has a capacity of 3,960 pounds at 95 psi.
I use E rating on my 14k implement trailer tires. 4 trailer tires, mounted, balanced, taxes $325 out the door for 4. The original tires lasted me 10 years. One went bad, I replaced all 4. I bought the same brand tire.
Just asking ? I just got a trailer and two of tires the tread is separating.
These tires were not balanced,
Some places dont balance tires , some do . With lead weight dynamic.
Some tires are out of round .
I think any way to balance them ,they are shaking the axle springs and frame so much the tires get hot and separate.
I got quotes for st205/75r15
75 mounted and balanced tow Maxs
85 mounted trailer king
140 mounted balanced Carlisle
What do you think?
560Dennis, I highly recommend stay away from anything 'ST'.
ST designates 'special trailer', tires are limited to trailer use only, which in my opinion opens the door to taking manufacturing shortcuts because the tires are not approved for anything hauling people.
Have had nothing but grief with them, one failed within 100 miles on an empty trailer! No more!
Never heard of that, we use them at work and get regularly inspected by the dot and never had an issue.
Tires separate because water gets in the casing and rusts out the cords. In repair school(yes it is a thing)they claimed most of the time you will find a repair 180 deg from the seperation. Radial tires will crack just enough to let water into the corde and again the cords rust out and break,= tread separation. I only buy bias ply tires for trailers, mine are worn out but after 23 years it is about time to buy new ones. 700-15 8 ply rating.
Jon f, that's good to hear. This was about 10 years ago neighbor came over ranting and carrying on how the county sheriff had him pulled over by Mankato for something else and said he had to change them. This was a 25-30ft livestock trailer so I don't know. Maybe he had little load range C or something on there. I know he had them mounted letters out and kept them armor-alled up nice and shiny.
