I am doing a valve job on my vac. It took a month to get the head back. I was quite methodical in keeping track of the parts--so I thought. As I put it back together i have 6 thin washers with 1/2 hole and 1 outside diameter I don't what to do with. I don't have 6 of anything that I can see. Closest thing would be the 3 bolts that hold the rocker assembly, if those are doubled some where. And the three bolts that fasten that assembly--3 have lock washers, and 2 have a thick flat washer. I cannot find a 3rd one of those anywhere. so either the center one doesn't use that washer or I need to go back and look in every corner for that.
I used to be able to pull up the parts manual on the net but can't find it now. If someone could post the page with the head parts I probably could figure it out, but I will take any 2 cents at this time. Thanks all.
