gac
Hello all,
I have a W-4 and broke the end off the valve stem trying to put air in it. Tractor currently doesn't run and i don't want to get put a lot into it. Any suggestions on how I can seal it up so I can move it around without losing all the fluid?
Thanks,
The tubes have two stems, the one that broke is probably the smaller one on the out side. Change the inner one and you will be OK,There are two threads made, inside and outside any tire store that sell tractor tires will fix you up with both and you will see what I mean when you see the new ones.
