Victor gauges problem
drsportster
There are five ports at the gauge 1 Line from tank 2 hose out 3low press gauge 4 high pressure gauge 5 What is a brass fitting which seems to be a relief valve of sorts . As soon as I turn on the oxygen the little fitting gives an air blast through small holes . It keeps doing it making it impossible to use the torch . Do you think I need a whole new gauge cluster or just that little brass part? I need my tanks for a boat job .
Likely a new gauge will be less than a rebuild, if you can find a place that will do it anymore. Most places around here quit doing gauge repairs due to their rebuild cost compared to a new one. And some had to stop for the liability issue with insurance coverage.
I wouldn't use that gauge until it was repaired or replace it. If that is pure oxygen leaking out of that fitting and it would accidently blow across a greasy glove or hand it could ignite and it would be like a blow torch. I've seen this happen once, guy opened the oxygen valve while wearing a greasy glove. Luckily no one was injured but caused some excitement in the shop melted down the gauge till someone shut the valve. Not saying this would happen in this case, just a possibility.
