Voltage Regulator Question
super99
I need a voltage regulator for my Oliver 550, 12 volt pos ground. I have a Delco number for it, I'll try Napa tomorrow and see if they can get me one. Just wondering, does the regulator know if it's pos or neg ground or could it work either way? Thanks, Chris
The older ones did matter. Something about the alloy in the contacts. The regulators were closely matched to the generator output, had high quality components, lasted a long time.
Not so with the new ones.
Have you tried cleaning the contacts on the old one? That will usually bring one back to life. If it's an original, or even an old replacement, might be worth a try.
You need Delco PN 10DN and yes, polarity matters. The regulator can be re-charged as negative ground, or you could get one from the vendor that is charged for negative ground, and you will need to change it.
Best bet is to remove your generator, buy a VR and send both to a car electric shop that specializes in old cars, tractors. They will adjust your reg to the output of the gen, and make sure it's polarized.
There is a good video on Youtube showing how to clean the points on a voltage regulator and how to "Flash" the field so the regulator will function. It is a simple job to clean points on a regulator, also clean the terminals.
(quoted from post at 21:07:41 04/20/20) You need Delco PN 10DN and yes, polarity matters. The regulator can be re-charged as negative ground, or you could get one from the vendor that is charged for negative ground, and you will need to change it.
hat? A 10DN is a Delco alternator, not a VR????
hat? A 10DN is a Delco alternator, not a VR????[/quote]
Heh, I copied the wrong line! Oops. Sorry
PN ADR6001
(quoted from post at 18:07:41 04/20/20) You need Delco PN 10DN and yes, polarity matters. The regulator can be re-charged as negative ground, or you could get one from the vendor that is charged for negative ground, and you will need to change it.
"You need Delco PN 10DN and yes, polarity matters. The regulator can be re-charged as negative ground, or you could get one from the vendor that is charged for negative ground, and you will need to change it.
Best bet is to remove your generator, buy a VR and send both to a car electric shop that specializes in old cars, tractors. They will adjust your reg to the output of the gen, and make sure it's polarized."
TOTALLY false post.
"Delco 10DN " = a series of ALTERNATOR.
Commonly used mechanical voltage regulators can't get "recharged" to a different polarity.
However, generators may need to be "polarized", otherwise known as "flashed" (under certain circumstances).
Traditionally, mechanical VR polarity was determined by the specific type of metal used for each half of a pair of contacts.
That is reversed between regulators intended for (+) ground use and regulators intended for (-) ground use.
Longest contact point life and therefore VR life requires the regulator to be used with it's designed polarity.
All that being said, it seems many regulators being made and sold today are not rated for one polarity or the other, and the contacts aren't made from long-lasting QUALITY $$$ materials like they used to be.
Upside is that they can be used on either polarity (unless otherwise labelled).
Downside it that life expectancy is nowhere near that of the good old OEM units.
The info below is from Delco voltage regulator manual, likely, the basic contact material information applies to any QUALITY VR.
