AlanAtwood
I was under the impression I had a cutout relay o.n my tractor. I have the 4 position light switch LHDB:
But the guts loock a lot more complicated than a cut iut relay. The wire coming in to the top has batt voltage, and the wire coming in to the bottom is from the arm on gen. Field on gen goes back to the switch.
Grounding field on gen does not produce movement on the ammeter, hust a wiggle.
Connecting batt and arm/gen on the cjtout pegs the ammeter at discharge.. Gen passes motor test. Took it off and to alt shop and it is putting out 14v and 8 amps.
Is that a VR that someone put in place of a cutout relay and just wired it like a cutout relay?
I'm tempted to just get the universal relay from Brillman and put it on.
Thanks,
Alan
Thanks,
Alan
