Wagner Loader Mounting Bracket for Jubilee
Does anybody have a bracket to mount a Wagner or Dearborn loader to the front of a Ford Jubilee tractor? I am looking to see if anybody may have salvaged a tractor with one, has one or can supply one for a pattern or has a pattern to fabricate one. I am concerned about trying to fab one myself and would prefer to find one that was made for the purpose. I've looked on Ebay and searched the web. I found one for the Ford 8N/9N but they are out of stock and wont work. Any help is appreciated and thanks to those who may respond.
Surf on down a few Boards to the Ford "N" Board and ask "The Old Hokie", he may be able to help you.
Unfortunately he can't. I called him after I found his website and he was the one who was out of stock of them for the 8N/9N and doesn't have one for the Jubilee. He suggested making one myself but I really an concerned about getting everything lined up properly which is why I'd like to find a salvage one off a tractor that had a front end loader.
I just took a loader off a Jubilee but have no idea what make it is. It is pretty crude. Has two lift cylinders and the small bucket is a trip type. No hydraulic pump either since it runs off the tractor's pump. Can you post a photo of your loader?
Here are some pics of my Jubliee with a Wagner loader.....maybe you can zoom in and might be able to see what you need to make.
HTH
That is very close to what I have except my bucket and frame are not quite as beefy. What I need is the bracket that is right under the radiator that is attached to the tractor that the loader frame attaches to. I cant see it from these pics and they wont let me zoom in. Also my the loader hydraulic pump mounts in front of the radiator and the pump drive shaft goes thru the crank hole and attaches to the crank pulley. I cant tell if your pump is in the same spot or not.
Your quest intrigues me. I have a Wagner loader that came off of a 600. My plan was to mount it on my Jubilee. Now, we may mount it on my sons Jubilee.
I was not aware that a hanger/bracket might be required. I will be watching your search. Also, I will go out tomorrow and take a look at mine.
The one thing I have noticed is, I think, that the grill has to be either removed or notched to allow clearence for the pump.
In some cases yes but my owners manual I downloaded off the net seems to indicate you don't have to notch Jubilees but you have to 8N and 9N
this is the front mount for a wagner loader, The three holes in the bottom is were the loader mts. The front cross bar/plate is were the pump mounts
