Water Tubes
molinegb
Anyone found a way to remove the water pipes between heads or blocks on a 206 220 motor without destroying them? Tried heat and soaking. They used to be reasonably priced. LIke 50$ now.
Might can try a threaded bolt and a piece of hose you can expand inside of it as you tighten it, then work it back and forth or use a slide hammer on it.
