bv
Will a 2 bottom plow snap coupler for a CA work on a WD-45, I didn’t know if there’s a width difference, I’m using it in my garden so a 2 plow would be nice
Seems to me the "CA' plow is slightly different with a shorter snap-coupler tongue and maybe the lift arm latches are a bit closer together ?? If you can lengthen the tongue, I'll bet the lift arms might work for what you are trying to do.
  • Like
Reactions: bv
Agree with Dr. Allis. There are differences. I have a manual for a no. 30/36 single action disc harrow and it shows different tongue for the CA and WD. If you back the tractor over it the lift links should be nearly plumb front to back when it is hooked up, side to side I am sure a little off won't matter. It appears that the lift links attach to the harrow closer to the harrow on the CA than the WD.
  • Like
Reactions: bv
