Yes it should, we run a small round baler and it doesn't take a great deal of horsepower, especially a WD45 with the hand clutch will make it work fine..never owned a WD but our neighbour had one and it was a fine tractor
The hydraulic system can be a bit of an issue. It is a high pressure low flow system that doesn't have a lot of volume. You would also need to plum in a two way valve. Or you could add on a crankshaft powered pump with seperate valves and reservoir.
WD45 if tat is in fact is what you have is 45HP and a tad bit low for some balers. Hyds are that big problem since they are set up as a one way system and a baler needs 2 way
I run a 605C vermeer with my WD45. Only problem I have is with the hills. Some times I have to go down hill with a near full bale. Mine is set up with a 2 way valve system for the loader. Its slow and not a large capacity baling system but my animals have never complained. Email me if you need some help. Tim from the rocking TJC
It depends on the baler. some take 80+ hp. I have a new holland chain baler and needs at least 75 horse. I have a wd45 too and it does have a high presser hydralics on it and will blow out cylinders and hoses. I would go with a 706 IHC. A real good tractor. That is just my opinion
Short answer, yes it can be done with SOME balers and with the addition of a valve. If you plan to do much baling, you would be time and money ahead to find another option before you break your WD-45s' back.
