flying belgian
Hauling beans 8 miles to market with my 2 wagons hooked together. front one holds 350 bushels and has breaks, back one 250. Heard a tire blow and looked in mirror as I was stopping only to see a cloud of smoke coming from back wagon. Well what a peculiar chain of events. It apears the rim split on a stearing wheel causing the tube to blow. when the loaded wagon dropped down on the rim it caused the stearing arm to break which then let the wheel turn perpendicular to direction of travel. So I dragged that flat tire crossways until I got stopped causeing it to burn smoke on the black top shoulder. This all happened in about 10 seconds time. I was so thankfull the wagon did not tip over. So I go home and get jacks and blocks and tools and take it all apart and weld the arm back and rob a tire off another wagon and put it all back together. When I am jacking it up to put tire on it slips off jack falling to the ground which caused one of the 4X6 to crack and dropping the box enough on that side that the wagon tips over in the ditch. Things could not have gone worse if I had tried. Anyway, rented a grain vac from the coop and sucked it up and into another wagon. Tipped the broken wagon uprite and finally got everything home. at 10:30. Whew.
Ouch!
Seems like my days like that start out with working a 12 hour shift here at work then I go home in the morning and figure on doing one small chore before bed. Something always goes wrong and then it just snowballs into an all day deal.
Glad you did not get hurt in all the whoo-rahh.
Least beans are up pretty good right now.
Dave
Sounds like some of my escapades. Sorry for your trouble, but at least you got the grain recovered. I don't think our local elevator has a grain vac, so it would have been grain scoop time for me.
Paul
Yup, we've all had days like that. One of our worst was cutting hay on July 4th w/e last year. Murphy brought his entire family that w/e.
Glad you were able to recover your crop and that you didn't get hurt when the wagon fell.
