Dave H (MI)
Name visible. Knurled knob at top, the threaded part comes inside slightly when turned. There is an outdent in the center that would appear to hold some specific item. The threaded rod at the bottom has an allen wrench pocket on the end to turn it into the 3/8 diameter hole (set screw). Aluminum body with steel hardware, making it not out of the question that this was home made as aluminum and brass are favorite materials for home machinists. But it is well made and could be commercially produced. No other markings. Body is 3 15/16 from flat to flat under screws. Inside diameter is too small for a Starret 25 series indicator and too large for the 80 series miniature indicators.
This came in a box lot of other tools. All were machinist setup items. I can tell you I have no idea what it is or does.
