what is it?
INCase
Cleaning out the barn and grainary at the farmstead and came across these
1st 2 pictures are what i think is maybe a maple syrup boiling tank? it is not steel as it is not rusty. its about 2ft by 3ft by 4ft in size. has 1 outlet on the bottom.
3rd picture is a rod.
I'm guessing a clamp for an old wooden wagon?????? or ???
(quoted from post at 08:17:24 07/20/22) Cleaning out the barn and grainary at the farmstead and came across these
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto130983.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto130984.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto130985.jpg>
It is not any sort of boiling pan. It wouldn't work because there is way too little surface area for the volume.
possible as it was in the grainary.
but a pretty small hole and no funnel' to the box to get all the seed/grain out.
The tank appears to be riveted together. Have all the corners been sealed with solder, brazing, etc.?
They did a lot of extra work shaping that flat sided funnel on the corner so that the flat is flush with the side of box.
Assuming the top is on opposite side of the funnel?
Also appears is was painted black outside, painted inside? Maybe gallvanized?
that rod looks like what was on the old grain wagons pulled with horses. the rear end gate was removable you loosen the rod then the endgate was lifted up.
You know a second look at that rod reminds me of the rods that held the factory stock rack together on the knaphide truck box we had on the 51 Ford.
Would have made a good sap tank for a pan. Drain it into the pan as it boils till you get enough to take a batch off then drain into pan again. Would hold a couple hundred gallon or so.
there are other wood horse drawn wagon parts around. in fact we have 2 Weber (says IH as well) wood wagon seats. also some wagon side extensions (parts) as well. They sold the wagon box at the auction but it didn't say Weber. it had the local hardware store name in huge lettering on the side. I suspect more parts burried in the hay and straw as well but a project for another day. have leaks and broken windows to fix 1st.
>>so it sounds like a wagon part anyway.
Thanks.
