I run a pair of old used 750X16 truck tires on the front of my 8N but my 8N has a loader and backhoe on itMy 1950 ford 8N has 16 inch front rims and I want to buy tires that have the widest width possible with our rubbing the frame. Is a 7.5X16 too wide? or do I need to by something more narrow?
What kind of loader on your 8N, Are the hydraulics strong enough to keep the loader and backhoe on all the time?I run a pair of old used 750X16 truck tires on the front of my 8N but my 8N has a loader and backhoe on it
The Loader is a Dearborn 19-71 model. The backhoe is a Scout brand they both run off a front mount hyd pump. It is set up so you can either use the loader or the back hoe but not both at once but then again who would use both at the same timeWhat kind of loader on your 8N, Are the hydraulics strong enough to keep the loader and backhoe on all the time?
Thank You, I would love to see A pic of that setup.The Loader is a Dearborn 19-71 model. The backhoe is a Scout brand they both run off a front mount hyd pump. It is set up so you can either use the loader or the back hoe but not both at once but then again who would use both at the same time
Where are you finding 6.00-16's for $130 a pair? Best prices I'm finding are $109 each for tri ribs.The ‘51 8N I bought has 7.5 tires on it. I had to flip the wheels around to make them clear the legs. It was not fun winching it onto the trailer with the cheap come along. They are definitely getting replaced with 5.50 or 6.00 very soon. Around $130 a pair.
