* Will this corn be any GOOD *
Dutchman
I seen this field of corn 15 miles away and was wondering ...
Will the corn be any good ???
Looking at picture .. West is on the Right .. as you can see the rows on the west made a snow fence and in the middle it cover the corn ...
I just bet the farmer was Glad that is All he had left to get out ...
Was just wondering ... Mark
Ps.. it's snowing right now ... w/ 2-4 inches on the ground and more coming ... more coming Sunday again ...
BOY am I getting tired of it .....
If it is not moldy, it will be ok. I cant say for sure how much will be left on the stalk.
If it is moldy, running it through a dryer will kill the mold but can still contain mycotoxins.
Yes, there will be corn there, might even be dry. Where the drifts are, the melting snow will pull the stalks down. Once the ground gets nice and dry I would slowly combine it with the snouts on the ground. Spoilage might not be an issue, unless it is a very wet and cold spring. You will get most of it, but you will still have a thick "corn field" in your bean field this year. If you have a lot a deer in the area, they take their share and waste a lot.
Been there and have had to combine corn like this.
Brian(MN)
If that field was around here a lot would be gone due to turkeys an deer by the time the snow disappeared. I had a couple of acres I couldn't pick until spring and it looked good until I got up close and found most of the kernels were gone.
It'll yield 20 bu or 40 bu an acre less, but it should be as good as what we got in the bins last fall.
--->Paul
Uncle and older brother had some corn standing overwinter a couple times. Uncle got about 70-80 bu/acre and feed some right away to dairy cows. brother turned out the feeder calves to clean up field. Father a couple times had spring farrow sows and little pigs to clean up over wintered corn. this was a long while back when fences were still up and livestock was available to do the gleaning. Past couple years sister and bil had some standing corn in low ground and had to try to combine in spring, gave it up and replanted corn in the patch. The ground has been put into conservation reserve now, no more worry and ducks have their spring nesting grounds. RN
Here in SE. SD, there are whole 1/4 sections of corn still standing. They say there is a 17 inch snow cover yet. It was plenty wet last fall so some guys left it or couldn"t keep up trying to dry it. One guy I know has piles of wet corn that he is now putting through the dryer.
A neighbor I am hauling for had a field that looked like that and when the snow settled, took the corn with it. The first 20 row he did not even shell.
