Wire feed welder penetration
Olliejunkie
I plan on doing a little welding in the morning. Dont want to start a fire at night. I hate welding when everything is dry. I ran a small bead tonight just to make sure I'm ready to go. I have the heat up all the way and the feed about 3/4. I would like a little more heat. Would it help to turn the feed down so I stay in the same spot longer? I usually only use it for spot welds and light stuff.
You can preheat with a torch
to get more penetration, or
run multiple passes. Trying to
use a welder that is short on
power for the job is asking
for trouble. Tell us what your
doing and it will be easier to
give advice.
Turning the feed down too low will cause the wire to melt back into the tip.
When I want to build a bigger puddle I just start making little triangles, letting they overlap until there is enough build up.
Thank you for the tips Jon and Steve. I bought another loader and small bale squeeze. The mounts dont match so I'm making an adapter. I took some 4 in tube and cut one side off to mount to my tractor and I'm welding angle on the other side to bolt to my loader and squeeze. I believe the tube is 3/16 and angle is 1/4. I know its light but it will get minimal use. I'm getting plenty of wire down just doesn't look like its getting the best penetration. I have 13 in of metal to weld times 2 on each piece.
(quoted from post at 20:27:19 06/28/19)
(quoted from post at 19:32:36 06/28/19) The mounts dont match so I'm making an adapter.
I know for that job, I'd never trust my Hobart flux-core wire feed.
I normally wouldn't but I welded some axles on a tedder not long ago and was surprised with the welds so I thought I would give it a try. If it doesn't work I will use my stick welder.
Faster wire speed increases welding amperage so if slowing it down results in too cool, then speeding it up should make it hotter.
Thanks. I will give it a try. Part of my problem is I have trouble seeing since I got bi focals. Hard to find the sweet spot. I use to have a cheater lens. I will have to look for it. I also may try my old glasses.
This topic comes up every so often. You control the current on a wire feed welder with the speed control, NOT the "other" control. The control you're calling "heat" is actually the voltage control. You'll get maximum current when the wire speed is cranked up as fast as it will go.
Since wire speed is the primary control, you adjust it first, then adjust the voltage. If you have recommended settings inside your welder, use them as a starting point. Then adjust the wire speed to get your desired penetration. Then, if you're getting too much spatter, turn the voltage down. If the wire is sticking, turn the voltage up.
With a stick welder, the farther you hold the stick from the work the hotter you burn. The closer you hold it, the colder you burn. To a point of course. Can't say if this holds true for mig welding or not. Could try it though.
What was said about WFS is true to a point but there is a limit to the amperage that a given wire size will allow. With the speed beyond that point it keeps welding but the amperage will not increase.
(quoted from post at 18:31:38 06/28/19) I plan on doing a little welding in the morning. Dont want to start a fire at night. I hate welding when everything is dry. I ran a small bead tonight just to make sure I'm ready to go. I have the heat up all the way and the feed about 3/4. I would like a little more heat. Would it help to turn the feed down so I stay in the same spot longer? I usually only use it for spot welds and light stuff.
Thank you for all the advice. I got some so so welds. Actually I think the first was the best then I went down hill. I dont know what I did different other than not cleaning the ground surface as well.
