Z129 rod problem
dodge tec
need help when i torque the rods its gets tight if i leave it loose like 8-10 pounds its fine the rods are in right with the dents on the bearing to the cam side and im re useing the rod bearings so i dont know what the deal is any help would be great thanks austin
Z129? What rod is that?
Assuming here that it was you who removed the shells, obviously not tight when you took them out, so, if it is the same crank (can't assume any of the expected details) you have put it back together wrong. Same shells in the original rods? Not clean between shells and rod/cap?
Is it all the bearings giving trouble or just one? May be the crank has been fitted with different size bearings at some time and you have mixed sizes (one loose and another tight)?
Now, if it was a basket case there might be anything included in the basket. Should these rods be shimmed?
Have you followed the workshop manual details?
Rod caps on the right way round.
Sounds to me like a case of needing to get the parts in their correct positions and the right way round (bearings and rod caps) and checking it out with the manual in front of you and a good micrometer in your hand.
RAB
fixed it thanks some dumb a** had 010 under bearings in a std crank
thanks for your thought's RAB but never asume who you are talking to i have 20 year in a shop seting with ford and cummins side of dodge i felt on the side of talked down to! what if you were talking to a kid and made him feel stupid
no need to nnalert them off
thanks Austin
