zenith carb interchange ability
55 50 Ron
What carbs would interchange or work on a Wisconsin engine that has Zenith # 13821? Searching for that number brings up 013694 as a suggestion. Anyone have experience with this?
Thanks I'm helping a friend who doesn't have computer access and I haven't seen the carb he has. The engine is on a Bobcat skid loader.
My friend called Bobcat, but they won't help. (sounds typical!!)
Ron, I've swapped out a number of those with MS carbs on small Farmalls from A, B, or the combine/swather engine which is either a 153 or 152. My standard was that shaft's turned the right direction and the Ventura was close in size. Why? I always liked the availability and simplicity of the Marvel to work on vs. Zenith. The gasket is easier to make and they just boil out better for me. The pot metal Carter was junk. I imagine someone will be able to give you a better, more specific answer. gm
(quoted from post at 11:43:57 06/03/19) What carbs would interchange or work on a Wisconsin engine that has Zenith # 13821? Searching for that number brings up 013694 as a suggestion. Anyone have experience with this?
Call a carb supplier such as Mark's Carburetion, likely there's a "universal" replacement Zenith carburetor available that will work.
(320) 393-7272
New carb is still available but up near $300. I assume this is for a V4 Wisconsin?
If the carb is missing, you find one off a farm tractor with the same engine size. Like an IH 454?
Carb you want needs a 1.18" bore and jetted for a 140-155 cubic inch engine. I know the IH carb for the 454 has the two mounting bolts spaced 2 11/16" apart.
