Good afternoon. I'm working on a 530. I switched injector pumps with a spare that I had. Tractor ran great but pump leaked from the throttle shaft. I sent original pump out to be rebuilt. I lined the timing lines up in the window on the leaking pump and removed it. I put the rebuilt pump on then I checked the timing lines on it and they were not aligned. I removed the rebuilt pump, rotated it until timing lines were aligned but now the dots (on the end of the shaft and in the slot of the pump) are 180 degrees off. I'm confused and looking for some help as to what to do next.
