FarmerBlair
Hi,
I have an 8N (side mounted distributor) that is not starting. It is a 12 volt conversion.
The starter doesn't make a sound when pressing the starter button even using a newly charged battery. Prior to this, it always ran fine and would start right away even after sitting for months (in a barn). In this last case, the tractor sat for maybe 6 months before I went to try and start it.
It is possible I left the key in the "on" position all this time. I'm not sure now. The battery was pretty drained because it took almost overnight to charge it. In the meantime, I installed a different fully charged battery and still no response to the starter button. The wiring looked okay. I didn't block the clutch down, so it is possible it is stuck. But even so, I would think I would still hear even a faint sound if the starter is responding.
The tractor isn't close by (about 3hrs away), so before I go back and try to figure it out I was hoping someone here could suggest the more likely causes of the problem. My knowledge on electrical is not strong, so not sure what to check besides making sure the mice didn't eat the wiring. I'm thinking the easiest check would be to bypass the key switch, and, test the starter using jumpers. Besides that, I'm not sure what to do and don't want to start buying parts to find the problem. I guess I could figure a way to bypass the push button switch as well, but not sure the best way to do that. I wouldn't have thought leaving the key on for extended time would affect those parts though.
