tractordust
I needed to replace the 20+ year old radiator on me 8N.
I got it and shroud back on and now tractor isn't getting gas.
I don't know if taking the hood off shook up sediment in the gas tank or what.
Here is what the tractor does.
It starts, but stops due to lack of gas. The gas is on and choking doesn't matter.
I don't know what the piece is called. It is the metal tube that runs from carb to other side of tractor. When I drained the gas, I just loosened it on other side of tractor, opened gass at card, and it all drained. Then I tok that tube entirely off so it wasn't in my way getting hood off.
Once I got radiator on, I put the hood back on and put that tub back in place.
The tractor was starting but stopping due to lack of gas.
I closed the gas and took off and dumped out the sediment bowl. Then when I put it back and opened the gas, i guess I didn't tighten it enough to keep carb float closed. Because gas went into sediment bowl. But it was kind of a good thing because it flushed a TON of sediment out.
After that the tractor ran for maybe 25 minutes. I mowed a little to see how it did and if anythign lossened up. Then it just ated like it didn't have gas.
I am wondering if I just need to really clean the screen on my sediment bowl and just put it on and see if I can have gas flush out more sediment and keep repeating. Maybe even just open carb with bowl off and elt it flush out some. But no sediment really has come out since that first push. I also may have the sediment bowl too loose because I looked and it filled up with gas again.
Any tips? Everything ran fine before taking the stuff off to ptu radiator on. And the tractor totally ran better than it has in a longgg time for 25-30 minutes. Maybe I just need to clean sediment bowl / screaan, then make sure it is tight enough gas doesn't come out? Maybe gas caused sediment to float up and clogsomething...
Thanks.
This post was edited by tractordust on 08/02/2023 at 06:58 pm.
Thanks.
