(quoted from post at 09:57:08 09/10/23)
(quoted from post at 11:42:25 09/10/23)
(quoted from post at 05:39:10 09/10/23) Consider bulk 50 chain and cut to length.
Thanks. Where I live we don t have much. Even a trip back to the dealer to return the new chains I bought will be a 1.5 hour drive each way. I haven t gotten much help from them. They re nice and hard working, but i haven t found anyone there who knows any more than I do-and I m completely ignorant.
What I d really love to do is make the new chains work, but I don t see how I can get them over the front sprockets without getting further into dismantling the machine than I m comfortable with. It s old and I worry about breaking hard-to-replace parts, and the service manual calls for tools I ve never heard of.
So I m thinking I ll order new chains online, that separate, and try to get the dealer to take these back when I have time to get back down to Hilo.
Last night you posted you had not opened and looked at the chain because you didn't want to get it dirty. I have to wonder, have you actually opened one of the chain packages and looked at it to see if it is just a piece of chain about 70 inches long, or if it is an endless loop, since last night's post?
If you got the chain of the current part number I posted (RE28723 was the old part number for it), they should be just straight chain, not an endless loop. Have you looked at one of them, out of the package? Open it carefully in a clean place, lay them out on some newspaper, cardboard, sheet of poly, or such, and check.
I have opened packages to compare to an old part and returned them to the dealer if they are wrong. Minimize package damage when opening and keep them clean. If wrong put them back in the package and return them. Electrical parts are the ones commonly refused for return, if the packaging has been opened.
Call the dealer, tell them your concern, and see what they say about opening a package and comparing the new chain to your old chain. The parts catalog indicates they are just 112 links of chain, and you buy a connecting link and a half link separate. If they are in the package as endless loops, there should be a connecting link already installed (they can be hard to spot), so you wouldn't need to buy the connecting links. Open and look if you haven't already.
Why are you changing the chains? Are they worn out, jumping the sprockets, or breaking? What is the condition of the sprockets? If the teeth on the sprockets have a hook worn in them that will shorten chain life and can cause breakage. If so, they should be changed as well.
