So I had to split a tractor that had a rear soft plug leaking...and I belive im working on a 404 Int.? Since someone previouslly removed the original metal serial plate on left side of bell housing and according to most guys here they believe it was originallly a highway mower It has no fast hitch,or 3 point but a pto....wide front and power steering ...so I also I believe from what I see it had original industrial yellow paint ....
So when I split it I seen a different clutch dics that I have never seen before? It has 4 round pads on each side of clutch plate ? Not lot of disc left but Im not farming with it ...just going to put a loader on it for lifting things , and so Is this the type of clutch disc you got if you ordered a 404 for Non Farming use and if you ordered it for farm use and with fast hitch you got a Regular type dics? I really dont see how this has any use as the pads are so small in size? If I had a standard disc I would switch it ...this looks like another stupid idea from another 1950' graduaute from MIT who went to work at International ......So does anyone know the strry about this brain fart of an Idea ? And am I going to regret putting it back in the tractor ?
