I've been freeing up the sticky clutch pedal the last day or so. Spraying PB blast etc. Got the pedal retracting fine. New spring works good. Tractor had no springs on the pdeals at all. I decoded to look inside the inspection hole in the bell housing. Looks like my throwout bearing is shot. The graphite material is chipped amd breaking apart. The fingers on the pressure plate have about a half inch gap between them and throwout bearing. I was hoping not to have to split the tractor but it looks now like I don't have a choice. Any tricks I need to know before doing this? I have an engine hoist so plan to use that to hold up the front end after ai split the cub in half, and brace up the back woth jack stamds and chocks. Anything special regarding changing out the clutch disc, pressure plate, etc? Anything I should be looking for?
This post was edited by Poonie on 11/01/2023 at 11:31 am.
