Hello all hoping someone can help us troubleshoot a 1959 IH B275. Being my first tractor and the first diesel I've ever messed with, I hope I could type this out and somewhat sound like I know what I'm talking about lol. I'll try my best.
The previous owner is my neighbor & he is helping me troubleshoot also. He said when he purchased the tractor years back he installed 4 new glow plugs & heat resistor indicator which instantly burned up when he tried to use it. He tried to replace it three times over the years and all three times it burned up.
I told him I was going to purchase a new indicator & he insisted on checking the wiring so we can get to the bottom of why the heat resistor indicator keeps getting fried.
Today my new part arrived and he noticed the metal coil inside the part was thicker and heavier than the part that has burned up on him several times.
I installed the resistor indicator and we went to try it and nothing happened. I suppose this is a good thing because we were expecting it to burn up.
So on my dashboard there is a black button which is the switch to engage the glow plugs. We started testing there in the switch is getting power. We then tested the new resistor indicator which is also getting power.
We then went to the first glow plug which I believe would be glow plug #4 (towards the rear of the engine) and again we found power. Upon trying the next glow plug #3 no power.
We took out glow plug #3 & cleaned the connectors and still no power. We then switched glow plug #3 & #4 and the same thing happened. We had power to glow plug #4 and glow plug number 3 nothing.
Up at the front just behind the radiator I found a good solid ground coming from glow plug number 1. I took some photos. Hoping something will catch someone's eye.
So from what I understand, the key turns one click clockwise. Then you hold the black button where the resistor indicator should begin to glow. Then a red button spins the starter. Would sure like to get off this ether lol.
