K9dukedale
Good Morning,
I am new to the forum and am inquiring about some advice on a G10 tractor with a Ford 172 paired with a TSX-813 (type c I believe with the power load needle in the bottom of bowl)
This machine has been parked after previous attempts at getting her going.
I have noticed that someone has rebuilt the carburetor, installed a new distributor, and wires. The needle in the bowl was in about half a thread on the verge of falling out. So I went through everything and set the screws 1 turn out from what I can find online. Adjusted point gap to .018 as I couldn't find the actual requirement. And timed the distributor to where I cab actually get the machine running. It idles perfectly fine however has a choppy bog when throttling. I tore into the carb to adjust the float height to 1/4" and still have the same issue.
It then dawned on me there doesn't appear to be a venturi in the carb. Based off of what diagrams I can find.
It may seem silly to ask but do all the TSX-813's have venturis? I wasn't sure if some or all did based on the differences between the power load valve.
