I've asked a couple of other questions previously on this project if the title seems familiar. We have a forklift based on a Ford 4000 4 cylinder tractor at our rail road museum I am trying to get running and its turning out to be quite different from what I know about my Farmall tractors. The machine was running fine until one day it wouldn't start. I volunteered to help get it running and the first thing I did was check for spark and it was good. Turned out the original problem was junk hanging up the float needle valve that was allowing gas to flood out the carb and then flood out the engine. I fixed that. Getting back to the spark issue the first thing I found was the resistor used for the 12 volt conversion was between the coil and the distributor. One of our attempts to check the voltage must have happened when the points were closed and the resistor began to smoke badly and since then we have had a weak spark. When I look up resistors for 12 volt conversions on this tractor there are two shown - one has a 2 ohm resistance which I use on my Farmalls and the other has a less than 1 ohm resistance which I don't under stand when it would be used at all. Can someone tell me what should be used on this tractor. The coil on the tractor says 12 volts with resistance or 6 volts. I'm thinking the fix to the machine without making it a 6 month project is to replace the points and condenser but I don't want to put on new parts and use the wrong resistor. I also don't want to spring for a different coil and remove the resistor either unless I have a better idea on what's happening. This has been a good project for me to further realize why I have only Farmall tractors because that is what I have learned to work on over the years.
