prairiecarr
I am working on refreshing a 1948 R series. It is the third one I have played with but the first one that I have had to go into trans and rear end. I need help with part number for the small roller bearing between the clutch shaft and upper sliding shaft. I came up with 94518 Hyatt but I understand that Hyatt and New Departure have been taken over by SKF. Parts stores cannot cross it. This is number 12 in picture. Also the double row cup on the sliding gear shaft, item number 6 in picture. The two bearings are Timken 15119 which are available but none of the parts stores can identify the double cup. Also how do you remove it. It has to go out to the rear of case but the front side is flush with the case so I can’t put a driver on it and can’t move it with a brass drift.
Any help is greatly appreciated, thanks in advance.
