Larry Barnes
Hi "Soaked" and all you guys.Hi Larry, I'd just blame in on fingers not rememering. If you had tied a string to one of em 3 years ago to remember the wires go in-- 180 out on the cap-- that string would be long gone!
Turns out the issue WAS the timing. My distributor was rigged up 180 degrees off. Not by me, mind you, but by a previous owner. The number one plug wire needed to be facing AWAY from the coil, the exact opposite of where it's supposed to be, according to Ford. Once the wires were routed 1-2-4-3 beginning from that point, it fired right up!
When it would not start a month or so ago, I had attacked it from all directions, by the book: New battery, electrical contacts cleaning, carb cleaning, adjusting points, new spark plugs, etc. But when I put it back together with your help, You Tube's help, and my original manual, it would NOT start. So today, a friend came over and helped identify TDC on the compression stoke. And we marked the flywheel with paint.
The funny part is that I went through the same battle in 2020. But my poor brain did not remember that "180 degree story" from then! So if I ever have the same issues again in 4 years, please remind me! I'm old and don't know what I'm doing!
