Hi Eman85 and others:
The story is that a couple months ago I unhooked my brush hog, hooked up my snow blade, and power washed the tractor (probably NOT a good idea). But started it right up, ran it for a bit, then I parked it in the barn. Barn is heated to 40 degrees. About a month a ago I needed to scrape snow, but it wouldn't start.
Cleaned and checked the points and replaced the plugs ( correct Autolites), cleaned the sediment bowl, took off the carburetor and cleaned all the holes and jets, etc., etc. Wondered if the the gas was too old (or got wet from the washing) and added 2 oz. of Seafoam. Bought a new 6 volt battery and cleaned all connections because it was cranking slow. Made sure all the plug wires were in the correct position with firing order 1-2-4-3. Got good spark. Carb back on. Won't start. Choke or no choke. 1/4 throttle and half throttle, no start. Rechecked the plugs. Not too wet, still got spark. Stuck my finger on each hole. Good compression. Won't start. Get one loud "pow" each time.
OK, I think maybe that means it's not timed right. (But remember, I drove it in the barn, so timing could not have changed just sitting there.) But hey, just checking (.025)and I know that cleaning the points may have changed that, so I loosened the bolt that holds the distributor in place, and rotated it from full advance to full retard positions and everywhere between. Still no start, just a "pow" now and then. Tried starting fluid. Just a bigger "POW" and no start.
So now, that's why I want to double check and/or reset the timing. But I can't find the marks on my flywheel. So it's back to the finger down #1 hole to find TDC. (That's hard to do when I can't see the points because I'm stretching to reach the starter button. So how do you know when you are actually at TDC? I feel the big puff, but it don't the pistons stop at the exact point, do they.? Or is that close enough to get it started, then use the timing light to get it spot on?
So after going through all these steps several times, it still won't start. Prided myself for years about not having to convert to 12 volt because it started so well. But now what do I do?
I appreciate you allowing me to vent my frustrations here, and look forward to reading your suggestions!
