mgrafton95
New to tractors here and looking for help! I have an old Farmall Super H. When i got the tractor, it was still a 6 volt system and would not start via the starter lever. The tractor would run, and ran pretty well; it just needed to be pop-started.
Converted it to a 12 volt system; new battery, alternator, coil, spark plugs, wiring harness. After I did that work, it ran well for a week or so. But then it started losing power while mowing and would run very rough. Assumed it was a carb/fuel issue since it ran for a while before the problems occured. I've tried rebuilding the carb I had as well as purchased a refurbished one. No luck with either of these. Currently, the tractor will start and run anywhere from 10 seconds to 2 minutes, then die. The whole time it's running rough. I'm not trying to move the tractor, just standing there messing with the idle and main jet screws on the carb trying to get it to run smooth.
I've double and triple checked that there's nothing plugged or dirty in the carb. The float works. I have a pretty steady stream of fuel coming through the line. I did notice that the coil is very hot to the touch (brushed my hand against it while pulling and cleaning spark plugs). Is it possible I got a bad NEW coil and that could be causing my issues? Would appreciate any opinions. At this point I don't know what to do.
