First time on here to post. I ve looked around a little bit, but that s it. Not sure I m posting this in the right spot but you will all let me know if not, I m sure. Haha. I have an old Ford tractor that we bought from a recently widowed neighbor. Her husband was in the middle of a tear down when he passed and we aquired it. Not sure if it s 9n or 2n.
We have it most of the way put back together and were ready to give it a test fire the other night. Brand new battery, hit the starter switch and the starter would barely turn, and slow at that. 6 volt system. I jumped the switch and hit it with jumper cables, same result. Pulled the starter and hit it with the cables and it spins okay, but starts out slow and winds up to speed, but it seems it s spinning too slow for no load. Front bronze bearing was sloppy so that has been replaced. Removed rotor and checked the commutator to rotor shaft with an ohm meter, no short. Checked field windings to case and no short, field brush to field brush so no resistance, reading of 0 ohms. Commutator has zero ohms from side to side although I haven t checked each individual bar to the bar next to it. After replacing the front bearing, I hit it again with the jumper cables and I can literally hold the shaft from spinning with little effort. Ant tips? And thank you in advance.
