Wico X4010 distributor parts wanted
Gambles
Getting an ancient Oliver 70 back from the grave. I'll be needing parts for a Wico X4010 distributor. I'll be doing a tune-up on the distributor and the one item that I need is the coil, which has a number of X6872. The tune-up kit is relatively easy to get, the coil is somewhat more scarce. Is there a specific "go to" company to get these parts from? Close up of coil is show. Photos are representative. TIA.
If that is a battery ign unit you can wire another coil outside. A lot cheaper too.
X2, if this isn't a "correct" restoration, simply use an external coil and tap into the distributor cap to get the high-tension lead to the center of the rotor.
On the other hand, I have one of the WICO units that works as for as I know, that I will never use.
