I've read a bit about the throttle adjustment on an AR. But I really don't understand how the throttle system works. I push the throttle forward to get full throttle, the engine speeds up, but here's where I lose it. I'm used to a throttle normally hitting a stop...that's it, no more. But on the AR, the spring set up baffles me.
When they say to increase the throttle to fast idle, I assume that means "full throttle? Then what is full throttle? When the engine speeds up, I can push the lever a loooong ways more which actually just bends the flat spring more.
I can't get full throttle without the spring pulling the throttle back and lowering the rpm. I don't see any way on mine to tighten the drag on the throttle lever itself. What am I missing here? I'm just not getting it!
