Around 2 1/2 “ or bigger ?I ordered a socket already. Used a punch and got the nut broke loose. That nut is the least of my worries.
I sure would not be leaving flywheel on. 10-20 is the same engine u have. And if you remove the flywheel u will know how to install it. This is 1920’s and 30’s info.That manual suggests the flywheel can stay on the crank when it is pulled from the case. Unwieldy, I'm sure and I see it's for a 10-20/15-30. What does it say about installing the flywheel? What service manual is that?
