Ok, latest update.
I have not installed the ignition components yet. I replaced the sediment bowl and fuel line. No more leaks. After that, it fired right up and would run at various rpm's.
Current issue though is that to keep it running i have to choke it for a couple of seconds and then no choke. It will run for a while, start to stumble and die, but then a brief choke will bring it back to life and run for a bit again. It's not like it wants partial choke all the time either. If I try partial choke it just runs crappy the whole time and will still stumble and die if I don't go to pull choke.
I was initially thinking there may be a sticky needle/seat but I don't know how that would tie into the choke or how that would momentarily resolve the problem.
The carb was completely disassembled (aside from the throttle and choke shafts/plates, cleaned in an ultrasonic, and every passage blown out. It's perfectly clean in my mind. Idle and Power needle are both 1 turn out per the manual. Float is set a 1/4" of the gasket surface per the manual.
Any thoughts?
Any thoughts?
