2014 Acadia headlights
Simple internet search found these.
My wife's Cavalier (2003) seemed like it had candles ,even when new.
With age the lenses got cloudy so I sanded and clear coated them and got a more powerful stock replacement bulb.
and it did help , they're not great but they're whiter and have a little farther beam.
these are the brand . I don't remember which ones I used.
Some lights just don't shine as well as others our older Cavalier (95) was much better.
How are those supposed to fit a
Hit the wrong year model. Sorry. Try these. There are more. These are the first that came up. It is a simple search. I went to yahoo search window and typed in 2014 gmc Acadia headlight replacement led. Took me 30 seconds to find these.
You can replace the OEM bulbs with Sylvania Silverstar Ultras. They will be noticeably brighter than the standard bulbs. HOWEVER, the bulb life of the Silverstar Ultras is significantly shorter than the standards. Given what a PITA it is to change out the bulbs on an Acadia, the better light is hardly worth the aggravation. (If the 2014 is the same as our 2012, you have to remove several of the wheel well liner screws, and often as not some of them will break or the heads will strip out.) I put the Silverstar Ultras in our Acadia, but one burned out after only a year so I went back to standard bulbs. Silverstar Ultra bulbs are available at most auto parts stores. Sylvania also offers the slightly dimmer Silverstar (no Ultra) bulbs, which I assume have a little better life than the Ultras.
Or you could get those cataracts fixed.
  • Like
Reactions: wh
Or he could go by a GM dealer and ask them what is available.
