Hydraulic Pump On A WD45 Engine
KCTractors
Location
Central Wi
I just picked up this WD that has a WD45 engine. I have been told that. I don't know much about an Allis Chalmers Wd or WD45 tractors as far as the differences. I believe the tractor is a Wd because of the straight transmission shifter.
I know one thing, this is a not a tractor for short old man. I almost fill off this thing twice already getting on and off. But now the question. This tractor has a hydraulic pump mounted on the rear of the distributor, has a New Idea loader frame for the reservoir and a two spool hydraulic valve mounted on the fender. Was this a popular set-up? I don't know if I am going to part the tractor out or keep it whole. I bought it for the nice 13.6 x 28" Firestone tires.
I got it running after cleaning the carb, has very good compression. Guy I bought it from said that it leaked oil from the rear main. The rear main leaked a little when I first started it but after running it about half hour, there is no leak at all.
Does anybody know anything about this pump and what else that it may fit?
Looks like it would fit anything with a magneto. It would be very rare to find a WD45 engine with a magneto/magneto drive. I suppose if it came out of a power unit, maybe. This engine is most likely a WD engine with that magneto drive on it.
I was told this a WD 45 engine. I have no idea.
The early D-17's had a gear driven/governor driven power steering pump, yes. It was 8 GPM and 1600 psi max. They had issues with the governor gear wearing out the woodruff keyway on the pump shaft. So, I can only imagine a 12 GPM @ 2,000 psi pump would only be worse. Of course, I am guessing at those numbers, but I'll bet I'm very close.
It looks like an oil line going to the governor which would be a 45 engine. However the oil fill casting looks like WD. If you look at the engine serial no. on the block behind the carburetor it should say "WD" or "45".
Does the engine have a steel plate on the side of the block? That’s usually the easiest way to tell aWD from a WD45 engine.
Even that’s not foolproof though, I’ve seen wd blocks with wd45 crank and I’ve seen 1 wd45 block with a wd crank.
Good point.
No plate on the block. Does this mean anything?
Anytime you find a plate on the carburetor side (left side) of the engine, the block has been frozen and cracked lengthwise. I've seen several WC's over the decades that had to be plated to repair a cracked block casting. I've also seen several that the crack was brazed for a repair.
