900 Case injector pump
ken golko
I had the injector pump on my 900 Case rebuilt, or so they claimed at the place that did the work and after installing it I found out that the transfer pump isn’t working. They said they can’t get parts for it. Is the transfer pump external , if so is it the piece attached to the pump and the lines from the filters are attached
This is the original pump.i also have another pump that i got. The second photo is the other pump. Just wondering if the piece showing on the pump in the second photo is a transfer pump.
You can add an electric fuel pump to push fuel to the injection pump. Do you have the original pump or a inline Bosch pump?
The FIRST photo shows the three bolt on transfer pump. It's a piston pump that CAN be repaired with new check valves if needed. DGK 301 is the repair kit number for the supply pump.
Thanks. I’m going to switch out the transfer pump first and see if that works
Where are you from? I’m in Manitoba.I may have to order a kit from your local diesel injection shop
How about Western Diesel Injection, Brandon MB 204-725-1435 says they’re the only Bosch dealer in western MB. I have no personal experience with them just found by a web search.
BTW, if you check his profile it shows you he is from Akron, IN USA.
You can add your location to your profile and it will show in your avatar when you make a post, like Dieseltech's, used redMN's, mine and many others do.
Thanks. Will definitely check them out. I’m disappointed with ADF Diesel in Winnipeg. Not satisfied with their service.
