Hey. looking to buy a gleaner M2 combine. With six row corn head. 4500$ 1500 engine hours on tac
Serial Number is MKS 18738 It’s been inside since I can remember farmer down the road owned and used in until 2023. All the belts are decent without dry rot. And the drives belts still have deep groves and aren’t worn smooth. Any advice on what to look for. if they are good or bad machine. Thank you all for any advice.
I have about 20 acres of corn to do. Will have about 30 next year.
If there was still a Gleaner dealer nearby I'd still have one. In todays' corn an M2 with a six row head will be a slow go with a lot of dumping. But that's a big machine for your acreage. My six row combine holds 250 bushels and it still can be a challenge getting around some fields to open them up.
That’s low hours if accurate.
Unload auger can get weak coming out of the bin wear thin, as well as the ball bearings in the swivel.
But doesn’t sound like you are at those hours shouldn’t be an issue.
I’m getting one with more hours but all 3 heads for same price about.
Paul
Can't go wrong with that one. I had an M3 for about 15 years, rolled almost 2000 hours on it with minimal downtime. Mine was a hydro with the 426 engine, the 301 might be a bit underpowered with a hydro trans and a 6 row in soft field conditions. Get the manuals and keep it serviced...an easy combine to set and operate. Good Luck and have fun with it.
Ben
An M2 is a good combine. That said, all machines break down and require high-dollar maintenance.
If there was anyone in your area who does timely custom harvesting, I'd look into going that route for 30 acres.
Is it gear drive or hydro? Floating tank fill auger with attached extensions or mesh tank extensions? 130 or 145 hp? The shoe was lengthened in later models, can't remember what year. Hill side blower? Tanks on the early ones were rated at 165 bu, later were 180bu. Had an early M-2 gear drive and a M-3 hydro.
It’s gear drive. floating tank filler with attached extension. I believe 130hp has side hill blower
I bought the combine with 6 row corn head drove it home clean and greased and lubricated chains and shorten some. Only problem I have is when heeding up hill on the road in high gear the engine stays reved up but the combine slows to a crawl. Seems like something is slipping.
When you change speed with the variable speed , is it quick and abrupt or slow and easy? Been a long time since I had one, but I think there is a torque sensor on the transmission , think there was a grease zerk, sensor could be stuck. On the speed change there is a check valve back in the valve stacks.
Variable speed drive belt is tightened with an adjustable idler. There is a procedure. With the variable speed all the way slow, the bottom sheaves should not touch. In other words, something like a knife blade should slide in between the sheave halves. And as big orange indicates, there is a torque sensing mechanism, I believe in the lower, spring loaded drive pulley, which could be malfunctioning. A worn belt won't tighten like it should.
Not to disagree, cause I may be wrong, but aren't you talking about the header drive belt? I can't recall a idler on the gear drive traction belt. As I recall there was a pivot adjuster on the rear pulley. I remember tapping the rear pulley for a zerk so it would slide in and out easier. Been 41 years since I had one so could be wrong.
Early Gleaners did not have a traction drive belt idler. You had to slide the main shaft back. I don't remember when the idler was added, but certainly by the time of the M2, it had an adjustable idler on the traction drive belt. (Not spring loaded) My K2 and F2 both had the adjustable idler. If I am remembering correctly, the hydros had a spring loaded idler on the multi band traction drive belt.
The hydraulically moved sheaves are on the main shaft, and the spring loaded sheaves are on the transmission input shaft.
I checked on Agco parts on line, that I can see the M series gear drive have no extra idler. That was from early M-2's to 22xxx serials.
It does not have an idler pulley for traction drive. Belt is a little loose probably should get a new one eventually. Got a book on the machine coming so will follow the procedure for adjusting soon. Thanks everyone for the help. I’ve never ran a combine so any help is super appreciated!
There's a period of time I'm missing. Or else a part of my brain that's missing! Certainly operating from old memories is hit and miss.
Early Gleaners (A,E,C) had a movable main shaft which allowed you to tension the traction drive belt. I'm thinking that by the K,F,G the main shaft was fixed. I remember putting a traction drive belt on a K on the back side of a swamp. I remember it as I had to cross the swamp twice, because the parts man gave me the wrong belt! I'm thinking that K did not have an idler. So certainly there was a period of time when there was none. This is leaving me baffled as to how that worked. Those belts are subject to a lot of wear. When stretched too long and/or worn, and the variable speed all the way slow, the bottom sheaves can bottom out, the belt loses tension, and the combine stops in its tracks! My K2 and F2 both had an idler pulley. It had a long draw bolt as well as the through bolt. All of the M and L series I recall were hydrostatic drive. I cannot get the Agco parts site to work. I either get Massey Ferguson or rotary Gleaners. So I will be very interested in how you make out.
Combine should be functional everything is working and adjusted according to book. Probably gonna need some fine tuning. But should be close. Except for I need two of the spiral noses come thing on the stalk rolls. Part number is disconnected. Hopefully I can find a parts head somewhere
