'51 8n side mount question
boler76
this tractor arrived in bad shape, the engine oil pick up tube came loose and sucked air damaging engine badly, I installed new cam, had crank redone , installed new sleeves pistons , new valve train etc, engine now runs very nice and smooth when cold but as it starts to warm up there is popping sound in exhaust, which gets worse as motor gets up to temp, have changed coil, condenser, plugs but no difference, there is 120 - 122 psi compression and 18 in vacuum , when choke is pulled slightly engine smooths out some and speeds up, the small carb screw is adjusted in as far as it will go, backing it out makes it run worse, I need suggestions thanks
Sounds like you need to adjust the valves sound like you have exhaust valves not closing all the way
My first thought is a crack in the manifold opening up as it gets hot. That would cause it to pull in air which is why it runs better when you choke it a little. You could spray some starting fluid around the manifold and listen for a change in the engine.
Hi boler76,
Is the popping only at idle?
When its warmed up, does it hesitate, surge, or bog down like its running lean, at higher than idle rpms, or does it run fine?
A restricted carb idle circuit would only cause low rpm issues
Hi boler76,
runs fine at higher than medium idle
Could be dirty idle curcuit in the carb
Most of my 8ns--- clone or MS carb, run with idle mix screw about 1/2 turn out.
Idle curcuit headwaters are where the .048 wire pokes out just above the main jet. (Sometimes the stepped passage is partially blocked with sediments)
These pics show poking a wire through the primary idle orifce and down to the spot the idle mix screw lives.
Not sure if the lower secondary orifice can take a wire through also. (Been awhile.)
Get a cheep clone to try, if you dont have a spare already. Spares are good!😀
thanks will see what I can do about that today much appreciate th input
thank you, very good picture of what I will try to do today much appreciated
as a follow up.. the engine runs well now, no popping and runs smooth at all throttle openings, The cure was ;; I made one good carb out of 2 originals and one aftermarket new one, I dont have the tools or parts to rebuild the original one, but this worked and I appreciate all the input from this site thanks
O'Reilly's and NAPA both sell rebuild kits for the carbs that came on these tractors.
rebuild kit would be nice but how to tell which jet goes were and get the old jets out? thanks for the input it is apprcited and at 87 I think i will just be happy I got it running with the parts I had
