this tractor arrived in bad shape, the engine oil pick up tube came loose and sucked air damaging engine badly, I installed new cam, had crank redone , installed new sleeves pistons , new valve train etc, engine now runs very nice and smooth when cold but as it starts to warm up there is popping sound in exhaust, which gets worse as motor gets up to temp, have changed coil, condenser, plugs but no difference, there is 120 - 122 psi compression and 18 in vacuum , when choke is pulled slightly engine smooths out some and speeds up, the small carb screw is adjusted in as far as it will go, backing it out makes it run worse, I need suggestions thanks
