oliver 70 engine
What are the goal and objectives? Pulling?
The stock engine has limitations, namely parts availability. If I remember correctly, if you're going custom, you're going to be sinking a lot of time and money into it and you're probably better off with another tractor like a 77.
how big can that engine be made into , or whats the biggest that will fit in
Gasoline 4-speed 2WD
April 13 - 24, 1936
Link: Nebraska Tractor Test 252 file
Belt power (max)28.40 hp
21.2 kW
Belt fuel use (max)2.7 gal/hour
10.2 l/hour
Drawbar performance
Max power21.93 hp
16.4 kW
Gasoline 18-speed 2WD
May 7 - 22, 1970
Link: Nebraska Tractor Test 1042 file
PTO performance
Power at rated engine speed70.27 hp
52.4 kW
Fuel use6.6 gal/hour
25.0 l/hour
Drawbar performance
Max power57.44 hp
42.8 kW
Oliver
gasoline
6-cylinder
liquid-cooled
Displacement201.3 ci
3.3 L
Bore/Stroke3.125x4.375 inches
79 x 111 mm
Air cleaneroil bath
Rated RPM1500
Firing order1-5-3-6-2-4
Oil capacity5 qts
4.7 L
Coolant capacity4.5 qts
4.3 L
Oliver-Waukesha
gasoline
6-cylinder
liquid-cooled
Displacement265 ci
4.3 L
Bore/Stroke3.75x4.00 inches
95 x 102 mm
Air cleanerdry
Compression8.5:1
Rated RPM2200
Starter volts12
Oil capacity8 qts
7.6 L
Coolant capacity20 qts
18.9 L
Good morning, I’ve attached two pictures for your enjoyment. I do have a third tractor but didn’t have a picture of it.
The Hart Parr 70 I did a bit of work on it quite a few years ago, if I remember correctly it Dino at 50 horse and we could weight it in at 3200 pounds with a 175 driver quite easily. We put bigger sleeves and piston in it for sure. I also have an Oliver 70 that we pulled prior to doing the Hart Parr, that one would also slide into to 3500 pounds quite easy. If I remember that one would put out 39 on the Dyno. Lastly is a 77 diesel. Put in larger sleeves and pistons, did an offset grind to the crank, shaved pistons down to top on block deck. Pulled 3500 on up, +55 horsepower.
I don’t pull anymore so any and all are available.
allready have the 70 row crop with no other use for it, any aluminum i got my hands on would go on the 37 wc allis
