thebubbleboy
Hello all,
I have come here over the years to read the wealth of knowledge posted but recently registered as I have a few questions that I couldn't find answers for using the search function.
I was having issues with my FEL and wanted to troubleshoot it and limit the possible problems.
Here is what I did:
Disconnect the FEL and coupled the hydraulic pressure line back together like it was before it had a FEL.
Drained all the fluid, cleaned the filter screen (was not dirty at all) and replaced the fluid with J20A fluid. Is J20A fluid ok? Many posts talk about the old 303 fluid (obsolete) and this said "replaces old 303 fluid and is far superior" on the bucket so I figured it would be fine. Bought it at the local Tractor Supply.
Installed a high pressure gauge inline on the pressure line. Started the tractor and raised the 3 point to it's highest position. You can here the engine load up just a little. The highest reading I got was 500 psi at about 2200 rpm. It was about 420 psi at 1200 rpm.
I figured that the pump was shot so I ordered a new one (should be here before Monday). I just want some information for testing after I install the new pump.
After the pump is installed and I let it warm up and circulate the new oil for a few minutes, what pressure readings should I get when the 3 point is in maximum lift position?
Please look at the attached (2) photos and tell me what each of the circled items are. I love the old 2210 but the lack of a shop manual has always been an issue.
Is "A" the valve that regulates the 3 point pressure? It has a pretty stiff spring under there and a few shims. "B" has a very soft spring and no shims....is this something to do with the small lever that controls the drop rate of the 3 point?
"C" and "D" I didn't touch. Does anyone know what they are for?
I want to know that the pump, pressure settings, fluid and 3 point are all ok before I move on to the FEL issues. FEL problems will be addressed in a future post.
I've read several numbers as far as the maximum pressure that the 2210 should be set at. Mostly 2000 to 2250 psi. Is this correct? I don't want to leave power unused but I don't want to kill my new pump or snap the woodruff key. If the springs need more shims, about how much does each shim raise the pressure/thickness of the shim?
Thank you everyone who took the time to read this. I look forward to your advice. thebubbleboy
Here is what I did:
