Is it me? Or the smaller the tire the harder they are to change....shredded one on the tedder traveling across town...I've had an easier time with an 18.4-38??
I use a length of thread rod through the axle and bolted to to my work table. I then have two hands free to work the tire irons.
Working the inner tube in and over the wheel takes a little of strength. I use the smooth rounded end of a 9/16" combination wrench to help work the tube into place.
I bought the harbor Freight small tire changer a number of years ago. I can't remember what happened but I couldn't make it work. Visit to a professional tire shop and PRESTO! All done no problems. Should have gone there to begin with. The Harbor Freight thing is still out in my shed somewhere. You know, I thought it would be so easy and I would save money. Anyone want a Harbor Freight small tire changer at discount?
Yes they are and I'm talking as a person who did tire repair for a living a few times in my life. A old truck split rim is easier to me then a tire that size
I’d much rather change a 24.5 truck tire than I had a lawn mower tire. Other than slinging the extra weight, a 24.5 tire is lots easier to change.
Funny, I said the same thing about taking a tire to the tire shop a few days ago and got a tongue lashing!! 🤷‍♂️
Agreed. I used to say that once the bead is broken on a 11Rx24.5, I could have it off the rim in less than a minute. One time I timed myself. Wrong. It took a minute and 15 seconds. Of course, I have my home made tire tools. A piece of leaf spring welded to a 5 foot long inch pipe and a shorter one with a smaller leaf spring on 3 foot piece of 3/4 inch pipe. The leaf springs are ground down to be real smooth so they will slide.
OP, here's the recent thread where this was just being discussed:
I have struggled with those small tires too. After wrestling for an hour to put new tires on a 12 horse lawn tractor once, I gave up and took it to a nearby tire shop. The guy looked at me with a HEH HEH under his breath. He greased the flanges and started the bead, then walked to a floor mat, dropped to his knees and pushed it on to the rim. I just walked away shaking my head.
I bought a HF small tire changing device that clamps to your work bench....works pretty good but still needs a little work with some extra tools and soapy water to get the job done.
I had always changed my lawn mower tires up until my hands started losing strength. Last spring I was able to put new tubes in the small tires on the seed and fertilizer spreader that holds a 50-pound bag of fertilize using two screwdrivers. They are very soft for a tire. I turned the spreader on its side and didn't take the wheel off the axle.
I've been switching to solid tires and wheels, rides a little rougher but worth it
I have Houston Clay soil and it is rough. I have a Ferris 61" ZT that is rough riding due to the soil. I ran the OEM tubeless tires at 5 PSI for a soft ride but they kept loosing air due to the turning in circles. I decided to put solids on the front and that was a waste of money. So I went to the spoked thing that JD offers on at least one of its ZTs rears but I got a pair that fit the fronts. Another waste of money.....I even cut every 2 out of 3 spokes out and the spokes then would bend on hitting a crack in the ground but the hard circumference ring pretty much stayed put.
I mentioned my frustration on here awhile back and somebody suggested that I put tubes in the front tires. I did and the problem is solved. I don't remember who posted that suggestion but I thank them very much!!!!!!!
The problem with OEM tubeless was at low air pressure and all the turning that the fronts of ZTs endure, the air in the tire would escape from where the tire is mounted to the wheel.....the tube, being self sealed, solved that problem.
